Hop-Ups that every Nitro machine should have done before it's first run.
WoodiE
Kind of good admin
Administrator
Lexington, KY
The review can be found here
Discuss away.
Ok I have MT12 rotary carb and need a throttle return spring. How do I get one? Can I use something I can find at home or do I have to go buy one at the LHS?
AE sells one in a little kit....just a spring and a little bracket type thing that has two holes in it, one you put under a screw and the other you hook the spring on to. I think they only run around $2 or $3.
this will work for any engine? I have seen the one for the AE .12 but not sure if it will work for the mt12
so what do you do with an engine with a slide carb. can you not use a throttle return spring.
I had never seen my Nitro MT handle so well and go so fast than the time my batteries went dead. It took off like a untrained dog who sees an open door and smells freedom!
