Is the fuel second hand too?
Fuel can go bad so whenever someone struggles, new fuel from a sealed bottle is #1. Save the old stuff for after its running correctly if you want to.
Your tune... it sounds like you are stuck on keeping your motor at 'factory settings' and then it doesn't run correctly.
If so, do not he afraid to tune away from those settings in order to make your engine run right.
Your tune can change from hour to hour or day to day.
Factory tune is a base line and is very helpful for when you've gone so far out of adjust, theres no way your engine could start.... factory settings are like a reset button.
Make sure your fuel lines are soft, not cracked. (They are cheap and take 5 mins to replace. I'd just replace them)
Is your aircleaner new, clean and oiled?
Fresh, CORRECT, brand name glowplug?
Is your fuel tank sealed? No air leaks if you blow into the fuel line WHEN THE TANK IS EMPTY!!!
Where its second hand, its best to start right at the begining and check ALL the free basics.
I would buy orings (and AE green slime) for the carb and replace those just so you know its done too.
Make sure the sringer in your exhaust is facing down so the pipe will drain.
Make sure you drain all the oil thats in there and be sure you haven't got a blockage in the pipe.
