Absolutely you MUST ditch that air filter. Get a 2 stage foam filter.
How it launches from a dead stop is all in the LSN. Adjusting it will also require an idle adjustment. Make small adjustments when the engine is up to proper temp, and run it around without going to WOT to see if it changed before adjusting it more. When you keep going too far in one shot, you'll never get it right. Once your idle is good and your launch is quick, only then do you start adjusting the HSN for WOT runs.
Every time you run you'll probably have to make a HSN adjustment for ambient temp and humidity, but the LSN can remain the same.
Get a temperature gauge. Leaning the LSN for proper launch can overheat the engine if you go TOO lean. Check it regularly while tuning.
