did it just all of a sudden start doing that?? If so then i would venture to guess that you have an air leak somewhere. Back Plate, Carb, seal these with rvt sealant. Also check the head to see how torqued it is, even a quarter turn loose on these and they will reep havok. Replace your fuel lines, then try again and see what happens. watch your fuel line for bubbles. And try your hsn at factory settings, I think on the picco it is 4 turns out, and on the bottom end at 7 1/2 - 8 turns out. That's all i got for now. what plug are you using? try the O.S. A-5, perfect for this mill. And last thing, are you using 20%?
