Powerman6766
RCTalk Qualifier
Here we go again...another problem to fix.Anyways today I set all my carb setting back to stock and found out that my LSN was 4 1/2 turns out.That may have been the problem. :smoke: Anyways I ran the truck once and it seemed to be doing pretty good on the stock setting but it sounded like it was getting to much fuel at low speed and high speed.So I turned to low speed in 1/2 a turn, and the high speed in 1/2 a turn.My truck dosn't coast by itself, thank god.So I don't have to mess with the idle screw.The second time I tried to start my truck is wouldn't start...finally it start but as soon as I took the glow igniter off it stalled.So I tookt he glow plug off and put it in the glow igniter and it hardly glowed.So I put a new one in my Savage.When I started it, it start right away.I pulled out of the garage and did half throttle untill I came to a dead-end an truned.Then I did almost full throttle and the truck just sat there spinning the slipper clutch. I walked up to it and the slipper clutch was slipping.(hints the name slipper clutch) Anyways I took it back to the garage and tightened to slipper clutch and it was still slipping.I got mad and tightened it all the way to see if it still slipped, and it did.The Gear has all its teeth still on it.But it won't stop slipping.Could this be that a put a new glow plug on it?I look at my origanl glow plug that came with the truck and it said R4 on it.And my new one said R3...This also happened to my brothers Savage when he switched to the new glow plugs we bought from our LHS.The new glow plug look like to old one except that have R3 on them...I am guessing that this means it runs hotter or colder...What should I do about the slipper clutch and if I have to buy replacment parts what do I need to buy?Sorry about the long post but I wanted to explain it as much as I could to prevent from haveing to explain more later.Any parts #'s would be nice.
