Here is a great tip!
Nitroaddict
Have you ever landed a huge jump a little nose down and had your ball joints pop off at the shocks?
Well, this easy tip will stop that from happening. Install a washer that is slightly larger than the captured ball. Place the washer on the outside then tighten down the 4-40 allen bolt as normal. The washer will prevent the shock end from popping off the ball.
I have provided a picture below to indicate how it should look.
courtesy of xtremerc.com
Been there done that...over and over and over again. Great tip, except you need strong rod ends otherwise expect to break a few on those really big airs. Voice of experience on this one.
cool - thanks for the tip! ubutomium shock shafts and RPM ends would be okay though, yes?
How about a pocket full of kryptonite just to keep Superman in check?
Dude that sounds like a rock solid combination.
LOL - i had to tdo that - after putting 4MM! front and rear towers on, those became my weak points
