Help!!!!!!!
REVOJACKSON
JACKSONVILLE FL
Help!! WHEEL SIZE PROBLEMS
I'm TRYING TO BUY SOME RIMS AND TIRES FOR MY 2008 REVO 3.3 CAN ANYONE TELL IF THESE WOULD WORK. HPI Mounted Phaltline Street Tires w/8-Spoke Chrome Wheels (2) - 17mm Hex - Fits Savage X & Others
(SPECS ARE AT BOTTOM)
Product Code: HPI4729 Qty:
Description
This is a set of two HPI Phaltline Mounted Tires on Chrome Blast 8-Spoke Wheels. These tires will give your street truck an awesome look, and they also help give you much better traction and handling on tar or concrete than stock or off-road tires will. These are a must for city drivers and show trucks. The wheels have a 17mm hex. Included with this set of wheels is a full set of 17mm hex hubs, so that you can run them on just about any truck originally equipped with 14mm hex hubs, like the T-Maxx, Savage 25, and others! These are perfect for the Savage X, XL, and other large trucks. If you would like a full set of four wheels and tires, purchase a quantity of "2" packages of these.
These are a great value! Pick up a set of these to see just how nice these are!
FEATURES:
Big Phaltline On-Road Tires
Blast chrome 8-Spoke Wheels
Molded Foam Inserts
Includes a full set of 17mm hexes for use on most 14mm hex equipped trucks
Phaltline tires premounted and glued on chrome Tremor wheels
Gives truck street-cred and high-performance tarmac handling
For Front or Rear Use
INCLUDES: Two Phaltline Tires Mounted on Chrome 8-Spoke Wheels
REQUIRES: Installation
SPECS:
Tire
Outer Diameter: 5.50" (140mm)
Inner Diameter: 4.4" (112mm)
Width: 2.7" (70mm)
Wheel
Outer Diameter: 4.4" (112mm)
Width: 2.84" (72mm)
Mounting Style: 17mm Hex Style
Yeah those would fit. You have the blue alluminum hex's right? if you do then those rims would fit as they are for a 17mm hex.
If your 3.3 is a 5309 model, it will have 14mm hexes and you'd have to get adapters to make them work. If your truck is a 5308, it will have 17mm hexes already. Bottom line, they will work regardless you just might have to spend a lil extra to get adapters.
Cheers,
Curt
you have to make sure that the hubs that you are getting are splined I have the ssame truck and I have to get splined rims
No you don't. The Traxxas hexes will work on nonsplined 17mm wheels. You just can't use the Traxxas wheels with the splined hexes on anything but the Traxxas hexes.
to tag on the obvious a little, just take note of tire size. I believe the stock revo wheels are 3.8" and final tire size is near ...crap, i forget ,i think around 6" Just be sure you aware of any diameter difference in wheels will have a significant impact on gearing either sacrificing top speed or acceleration.
If you have the 5308 with stock spur and wide ratio xmsn, then a slightly smaller tire might just make one mean street machine.
