help
Jlaw3.3
Lansing
what should i do
I put a 3.3 in n old .15 tmaxx and I keep having problems one after another what stuff should I change for this truck to work well with this engine.
I have a tmaxx .15 that I put a 3.3 in and I put new clutch bell,shoe,flywheel on it but now when i start it up and pull the throttle the truck doesn't move just revs up the gears are spinning but no accelleration anybody have any ideas of what might be wrong.
Check to make sure your slipper is not loose.
You need to put in a 3.3 transmission, upgrade all the driveshafts to steel dogbones or CVD's, stuff like that. I have a tranny for sale, I was just about giving it away. It's brand new with everything you would need. I have it on ebay now but if you want o buy it, I'll sell it to you and end the auction.
Tighen the slipper nut until it stops and then back it off 1/4 turn.
This will set the slipper on the spur gear.
If you give it throttle and the spur and slipper plates rotate and the truck does not move, check to see if the outdrive shafts from the tranny are rotating.
If they are not, then you have something wrong in your tranny, if they are, you have an issue in your F/R ends.
More than likely it is your slipper not be set properly though.
Threads merged and moved to the T-Maxx forum.
Please do not create multiple threads on the same subject.
Thanks
