Hi,
First thing, I did all by the book and wanted to start with priming the engine but roto-start seemed to weak to turn longer then 1/2 second if not less. This can't be normal can it - half a sec?! As is turned little fuel started to fill the fuel line and I couldn't have flooded the engine 'cause fuel didn't even got there yet. Do you think the battery was too weak, I did charge it for 50min a couple hours earlier (venom 3000, @ 4 Amps).
Did anyone experience this roto-start weakness? Do you suggest I use a cordless drill??
...then, after that I did use cordless drill and results improved, engine would start and run for about 3-4 seconds and then it would shut down, these were the best results I got today?
Any suggestions, comments???
thank you all
thank you all
