I just picked up a Sirio s27r but I'm confused with the instruction sheet it came with. Besides it beeing written in non-english english, it refers to 3 base speed needle/adjustments and 1 full speed needle.
Can someone give me a better definition of the needles/adjustments on exploded view of the carburator? For example, is part 160006 "base speed adjusting set" the idle setting??? Also, is part 160007 "base speed adjusting screw" the mid range needle???
Both the low speed and high speed needles are clear, it's just mid speed needle and idle setting I can't determine.
I checked teamtrinity's website and it uses the same names as this so called instruction sheet.
thanks
thanks
