Hi all, hoping you can help me with a revo I picked up cheap off eBay,I previously had an acme condor for a whole week which went on the scrappile and I've replaced it withe decent car!
The problem I'm having is trying to get the thing to start,I reset the needles to factory (hsn 4 turns out and lsn flush with housing,1mm carb gap) All the car will do is turn over,wont start,if I pull the throttle on the remote it will start,but only when the carb gap gets to about 4mm,it will tick over then but as soon as I let off the throttle it dies? I've replaced the glow plug,and it's lighting alright,and I'm running it on 20% fuel.
Any ideas before I replace the piston and sleeve,as there doesn't seem to be much pinch when the pistons at tdc?
