help with rolling.
Lower the truck so it doesn't have so much ground clearence, and stiffer springs and/or thicker oil will also help
Control the truck. Are you rolling over from landing jumps or just simple turning? Are you turning at high speeds? Tarant said it best, lower your truck dude. Bringing its center of gravity down will help keep the truck on its legs.
Also if you are in a turn at high speeds dont brake and turn at the same time, it will flip the truck especialy if you have very good brakes, I know with my maxx I have to slow down turn and speed out of the turn , if I brake and turn i roll my truck
cb95563 said:
any ideas how to stop the revo from rolling over so much?
It's all about throttle control and setup. Easy in to the turn, haard coming out of the turn. Don't make abrupt turns because CG is higher in MT's. Also, what type of surface are ou running on?
FastEddy said:
Its a local guy!
Welcome to RCNT.
Both RobMob and I are close to you.
I don't know if living this close to Ed is that exciting........ :jk:
Lucky to have them actually. I would be bugging both to go bash all the time if I did.
ok ... this is what I did and the thing is nearly unrollable
1) Get the Hardcore Racing full front to rear skid plate. This lowered the center of gravity bringing some additional weight to the bottom of the truck.
2) I got the hummer SUT body... which is super heavy
The truck will just slide all over the place.... (on dirt not on pavment ...of course)
The downside is.. the truck is alittle heavy!!! Great for bashers who spend most of the time upsidedown!!
Lower the center of gravity.
Dont take sharp turns at wot.
Learn how to drive.
I drove for 3 hrs today and didnt roll it once. :cheers: Practice practice and oh yea practice.
Regards
