help please
tobyrenton
united kingdom
i have just brought a hyper 7 off my mate it has a engine its got (36R) does any 1 now the name of this engine it needs a new 1 way bearing i can't find who sells it or any spares can any 1 help please
Hey Mate I am guessing this is the engine you have here. Do you know if it has an internal OWB or an external? The engine should be an Ofna/Hong Nor R36 5.9cc/.36 engine. I am doing some looking around and see what I can find. But in the mean time if it is just slipping on you and it is the internal one way....try pulling the glow plug or down the carb with a couple healthy shots of WD40 and turn the engine so it will flow to the back and maybe clean out the OWB a bit. If you have the external style it is under the pullstart cover and you can still pull the cover and hit it with DA and some WD-40 to clean it. They can get gummed up from the oil in the fuel.
****EDIT****
Ok after doing a bit of looking the other Force engines including the .32 have eternal OWB. ONLY GUESSING HERE but IF it has the same OWB this one from HPI should work.http://www.rcpitstop.co.uk/hpi-one-way-bearing-for-savage-family-hp1430-62-p.asp
The best thing for you to do now is pull off the plastic pull start cover (3-4 screws) and see what you have for a bearing. Let us know!!
