Hey guys, need your help....I have an OS Hyper CV-.12 in my RC10-GT. It starts and runs fine when its cold...After a tankful of fuel (updated RC10-GT Team Associated tank), it is very hard to start (I'm using a starter box). Head temp is 230F; It takes a long while to start it and I have to "goose the throttle on my radio and prime it several times to get it started. Once it starts and I rev it a few times, it idles fine, and runs fine. I'm using SIG fuel, 15% Nitro, HS needle is 1 3/4 and low speed needle is flush with it's housing. As I said once this engine starts, hot or cold , it idles well and runs strong with NO hesitation, if I change needle settings it definitely affects performance on the negative side. What do you think is causing the hard starting when it is hot? Thank you. (possibly a problem with the SIG fuel due to its high oil content?)
