https://www.rcnitrotalk.com/forum/picture.php?albumid=580&pictureid=3417
Hi all any suggestions would be fantastic here goes I've got an old g4 with a novarossi sx 12 engine it starts up stright away plenty of off the line and top end speed now after about half a tank approx 120c temp i stop then it just dies but the odd thing is it wont start again doesn't even sound to be fireing you can hear the presure poping as it should if i let it cool down five minutes its fires back up then five minutes later i stop to check temp around 120/130 then dies and over and over it does it again all running seams good thin trail of smoke on full throtle no bogging idel is all good.found fuel leaking on engine not from carb or any pipes can't see where so then started getting sick of it so out came the tools engine out heat sink off side case off piston out cleaned it all out with wd40 now very clean and shinny internaly put it all back together with gasket sealent nice and tight fires it up starts up keaner than ever no fuel to be seen leaking anywhere just need to take it for a few laps tomorrow,any suggestions if it continues to quit on me.thanks
