Pretty easy, pull the old engine, swap over the flywheel, clutch and bell gear and re-install it all. Should only be about a 30 minute project. Read the manual on it and it will show you most of what you need to know. Should be a screamer with that engine. I loved the .18TZ. Great little engine.
It is pretty easy, but not that easy. It can be tricky to get the gear meshed correctly, especially if you don't know what your doing.
There's a few key things to remember...
-When tightening down screws, tighten each screw, little by little, in an "X" pattern. I do this for everything on the motor, and don't forget to do it on the engine mount when tightening it down onto the chassis
-The gear mesh, like I mentioned earlier can be tricky for people who have not done it before. Since you have never done it before, use the paper trick. There's a link lower in the post to help you, but I have a couple tips for you. When I'm setting my gear mesh, I already have the engine locktited down to the mount, then I loosely tighten (make any sense?) down all 4 screws that hold the mount to the chassis, so then the mount will not move out of place but you can still make small adjustments by moving it by hand. Once your done with the paper trick and you think the mesh is good, try to spin the spur gear, check for any binding, if it does not spin freely then mesh is too tight. To be honest though, I don't use the paper trick anymore and I have never had problems.
-Locktite! Use it or you are setting yourself up for a disaster! I use the blue locktite on all 8 of the engine mount screws (4 that hold engine to mount and 4 that hold mount to chassis)
-Everyone's setup is different on their vehicles. But just make sure you have as much installed on the engine before you put the engine in. What I mean is, don't get the engine all locktited down and then notice you can't get to the header screws to tighten it down because something is in your way. It would suck to get it all down and then find out you have to pull it and do it all over again, almost happened to me when installing my new 2.5R into my tmaxx.
That's all that I can think of off the top of my head, I hope this helps. Here's the link to the paper trick....
http://www.rccoh.com/rc.how-to/set.spur.mesh.html
