Help Identify This Losi
Reddog
RCTalk Champion
Winfield IA
I got this Losi and believe it to be a XXL but am not certain. If anyone can help out with an exact identification that would be awesome. Thank You, Shaun
Looks like a XXL to me buddy :mustache:
One way to confirm is compare parts on your truck to some ebay part listings.
Thank You. It has some issues but I will get it going again. Shaun
The Aftershock is a cheaper version of the XXL, plastic shock bodies, no reverse, cheaper tx/rx, engine and pipe. Still a nice truck, I had one for a while and I really liked it. They also made one called a Mega Beetle (I think) it was the same as the Aftershock.
Yea. I'm going with either lst or aftershock. Arms are smaller, shocks are black plastic. Looks lie it's a different motor, or the head was stripped of paint. What does the motor say on it?
I will get some better pics later. What are the differences between the Aftershock and the XXL?
The XXL was Losi's latest LST platform, before the gas powered XXL2 of course. It was longer and wider with a few other upgrades over the other LST models
I'm leaning more towards the Aftershock, the LST2 came with aluminum shocks. The XXL came with plastic ones, but the chassis looks a little short. Doesn't really matter too much though, they all share the same basic setup so upgrades are pretty interchangeable. The cooling head is definitely not the stock one for the 454, I was guessing that it was an Axial engine to be honest, I guess the previous owner put a different head on it.
I was going off of the 454 that was on the side of the engine. Turns out that was just a decal or sticker because when I hit it with the air to clean it off a bit more it flew off. It does say axial on the head and has a black case. Again a motor I have not owned before. Sorry for the misinformation there. The spur gears are shot, and it rolls real rough. When I get done with the T Maxx I will get into it. Shaun
Could just be a plain old LST or LST2 with an engine swap.
I have an LST2 floating around somewhere ill put up some pics in a few hours.
That's an Aftershock for sure. The plastic shock bodies and the toe rods in the rear are a dead giveaway.
Engine is a Axial, .28 or .32.
Thank You all for your help. The Axial engine seems to be a rather solid engine, as far as I have read.
