help find this part please
striker
RCTalk Rookie
Hi everyone I'm kinda new to rc cars. i have a D&A Bungee http://www.rctoys4less.com/wholesale-Products/Default.aspx?ProductID=114 and I'm having bad luck. the throttle servo broke and the car crashed, now the plastic piece that the throttle rod hooks to on the carb broke. whats that piece called and where can i find one? The D&A website doesn't have a contact link for me to get in touch with them.
A picture would help or a link to the manual witht he part number that you are looking for.
thats the problem, the manual doesn't list the part i need. You can see it in the pic (the top of it) right beside the air filter. It's just a small piece of plastic with holes in it for the throttle rod to connect to it. It screws into the carb to open/close it.
OK, any reason you can't use or modify a plastic servo horn? ( the plastic part that bolts to the servo and is the other end of that linkage)
the piece on the car is alot smaller/thinner than the servos part, so I'm pretty sure it won't fit.
Hmm, do you know the brand of the engine? Have any better shots of that part? Most of these things are very similar to other companies parts and someone might recognize it if there is a better pic.
Hi Striker
If you have a dremmel or similar tool, you could make this part from scrap plastic.
Take the part off and scribe/draw around it on similar thickness plastic and use the dremmel to drill and shape it, and a piece of fine sand paper to tidy up the rough edges...
Hope this helps
hopper2
Thanks guys i wasn't sure what it was called but you all found it :D
