Hello.
corvey
england
Just bought my first nitro car. Acme CONQUISTADOR .
SPECIFICATIONS:
Width: 330MM
Height: 165MM
Track: 267MM
Length: 390MM
Wheel base: 280MM
Gear ratio: 10.44:1
Engine: New Team Infinity 18S
Wheel dia.: 108*56MM
Ground clearance (F/R): 38MM/46MM
FEATURES:
1/10 Scale nitro powered car
4WD Shaft drive system
Team Infinity high quality pull start engine
Oil-filled Alluminium shocks
Single speed gear box
Front and rear bevel differentials
75CC Fuel tank
Metal disc brake system
Pre-painted and cut body shell
Sealed box for protecting receiver system
High quality CE APPROVED OEM 27MHZ Radio system with changeable crystals.
Its not going so good. had it in for repair 3 times. Wouldnt start, exhaust broke, then pullstart broke and nor its just revving up and not moving. if i lift car off the ground the wheels spin a little but once its on the ground it just screams and goes nowhere. any idea?
I'm expecting msgs saying get a savage or t maxx instead:p
ill add some pics soon.
Thanks
Coyote gets all his supplies from Acme, and he's always having problems.
If the wheels don't turn on the ground but the engine revs, adjust the slipper clutch as needed. If that doesn't help, check inside the clutch bell on the front of the engine.
how do you adjust the slipper ? where is it? can u show me? sorry its my first nitro car.
thanks
corvey
few pics. I'm a newbie at this so i got no idea what I'm doing.
I took it appart for him today and found a slight problem with it.
Sorry for pic quality its too close up i think.
