heat cycle or standard break in
honda237
RCTalk Racer
vicksburg
I got an lrp .28 spec 3 engine for my lst and was wondering what you guys were recommending for breaking in the engine. I have heard alot of thing about heat cycling the engine. What would you guys recommend heat cycling or standard break in to manufacturers specs?:bow:
Definitely heat cycle. Your engine will last longer and you will get more performance out of them. It's all about taking your time during this period.
I use the heat cycle method. When animals use the heat cycle method, they almost always get pregnant, so I figure it has to work.
+1 on heat cycle. I used it on the Picco and it runs fast and hard, and even 2 gallons later it has a LOT of compression when warm.
