Well, once you have exhausted all the options of adjustments and checking the engines compression and condition, plus performing the cleaning, once your sure its not a matter of adjustments, i would move on to the gaskets and seals, they say even a pin hole in a gasket or seal can cause problems like what you are experiencing, when you cleaned the carb, did you make sure to clean all gaskets/seals and the surfaces they are sealing? If any gaskets or seals are dry, or cracked, it will cause problems, cleaning them, and were they should be, as well as lightly oiling the rubber seals to be sure they are not leaking, check and make sure some of them aren't visibly leaking, especially the gasket that goes between the engine head and engine block, the copper gasket is one you should not have to oil, but would suggest to clean, oil the rubber seals, also, try putting the glow in, and put some fuel or soap and water in there around the glow and turn it over, to be sure the gasket on the glow plug is not leaking.
If the copper gasket between the engine head and engine block is leaking, the engine will loose compression where the air and fuel will leak out, in most cases you will see the result in a leaky gasket in that location, for other seals in the carb if they are leaking, this will cause problems with how the fuel is passed through, and its ratio as it is being mixed with the oxygen, rendering all adjustments useless and inaccurate, another thing i am concerned about, is the fuel you are using, how old is it? usually fuel will keep for a long time, but it is always a possibility, i would be sure to check all gaskets and seals.
Once you have exhausted all the suggestions i have givin you, i will soon be out of options, where we have covered the majority of the engine, cleaning, adjustments, gaskets and seals, if no luck, after like i said, exhausting all options, i would then consider just ordering a new carb, and possibly piston/sleeve, witch you would then want to go ahead and replace the main bearings, it is important to check for any leaks, because so far i have my bet down that there is a leak somewhere, causing issues with the engines proper running cycle, i would suggest exhausting all these options before purchasing new parts to perform a rebuild!
