handleing problems
asphaltassassin
Hastings
t-maxx 4908 forward only can revearse be installed?
hey guys & gals I'm new to the site and hobbie. I just perchased a new truck on ebay and it was cheap price. it only has 2 speeds forward no reverse. I have another t-maxx with reverse and I like it. Do you know if I can convert it with reverse? maybe just put reverse gears in or change whole transmission. THANKS FOR YOUR HELP.
First off this should not be in the introduction forum.
Second, I can't even move the thread to the proper forum because you did not take the time to tell us what rig you are referring to.
You need to help us help you.
Welcome to RCNT, as per above post your question in the appropriate section with some more details and I'm sure we can help
Moved to Tmaxx forum. Welcome to RCNT.
Each wheel has a turnbuckle on it, and turning it will either set the wheels toe in, or toe out. You may also have to center your servo and control arm when you make your adjustments.
The front should be at zero or 1 degree out for aggressive steering control, and the rears should be about 2-3 degrees toe in.
The turnbuckle shown here is titanium with a hole to rotate it with an Allen wrench. Most of them will have a hex in the center.
The ends are threaded in opposite directions, so when you turn it, it will either get longer or shorter.
