I originally posted this thread regaurding what you should do with your body. The census was that you must run with the body on and if you need to tweak with it or start it, you should have some cut outs.
The window is a no brainer. The fuel tank and the rip cord are right there. I took a pic from top down then I played with it in photoshop to show where I'd like to cut the body. The only cut I dont like now is the gas tank one.
I read something about putting a ziptie on your gas tank lid so you can open it without getting burnt. Maybe I will make a small hole in the roof and thread the zip tie through it. This way I can pull up on the ziptie and sneak the gas nosel into the tank via the side window.
What do you guy think about my cuts? I can't get to the low speed needle easy (even with the body off it seems).
Here is the original pic if you'd like to draw on it:
I'd rather not slice into it knowing nothing about the process.
-rob
Originally posted by x_789
Since your truck resembels a GT some what I would cut out the window on the side where the tank is and possibly around the engine depending on how its done already. Most GT bodies for AE and TL have the whole rear open between back of roof and the shock towers... Not sure on your ride. Can you get us some pics of it with and with out the lid on top down preferably along with side shots...X
-rob
