hey guys... I've had my storm for a year. i ripped my stock chassis in the same spot.
i then got the fioroni chassis only to ream out the holes in the front. i sent the chassis back to fioroni and the gave me off a new one{which by the way was changed a little from the first chassis i got}
i also went to the pro{metal} susp. blocks. i believe those helped to wreck the chassis-loose screws my @ss.i always used loctite and checked screws. i started to use longer screws so if it broke{and they did-the screws that is} i could get the remaining part out of the block and reuse it.after going through like 3 sets of blocks at 40$ a pop, i went back to the plastic ones. i'ld rather replace an always stocked $4 part. then potentially damaging my chassis
well anyway... my new fioroni chassis has held up alot better....for those who didnt notice the switch was about 6-8 months ago{the new style had more areas drilled out to make it lighter} i think they removed some of the drilling out around the weak areas too.
which brings me to my first ?
the hinge pins sold on ebay are said to not work on the fioroni chassis. any 1 get around this? do they fit on the Ti chassis?
have any of you seen the slim chassis from fioroni? it looks like the removed the holes in question and give you some new alum. pieces to mount the arms/blocks to the chassis? here is the link to the fioroni page
http://www.gsracing.com/gsracing/page.asp?pg=products&catid=31&fatherid=8&rootid=1
heres the link to the conversion kit and chassis
http://www.gsracing.com/gsracing/page.asp?pg=products&catid=31&fatherid=8&rootid=1&id=429
is it to make the storm an on road vehicle or to solve the problem we have been discussing?
i trashed my BO1 trying to get the front bearing out so i got the os rz-v01B- i love it. i've seen several diff. thoughts on which tuned pipe to get...any thoughts on this - i stuck to my stock pipe for now. it is loud but read it gives you better low end then some tuned pipes.
you shouldve said - you hear it runnin bitch? lol
i can- by law continue to run this here well past 7 and am only turning it off to be cool to you. the fuel has to be run totally out to avoid possibly damaging the engine. i am trying to be as repectful as i can but if you keep giving me sh!t about it, i'll start running it till i have to stop-by law. not when YOU THINK when I should
