Gpm center skidplate question
If it's the same type of skid plate as mine (it looks like it is) the screws that hold the inside end of the front and rear skid plates (they go into the chassis braces) hold the center skid in place. The screws that came with the GPM are Machine threaded for aluminum chassis braces. If you have plastic still they would not have worked anyway.
Check that out, you may not need any new screws..
for plastic cross braces use HPI #Z632 - M4x10mm
For metal cross brace use HPI #Z613 - M4x10mm
