good or bad to put 3 speed in t maxx?
From what I have read the gearing is all off and low end power is non existent but I have never actually seem one run.
it depends on what you are running on. if it is tight stay with the 2 speed for better torque. are you going to be racing or what?
i would stay with the 2speed too.......less to break down & more power on the throttle........top speed will not be as much as a 3speed will though.......if you deside on the 3speed i would upgrade to a bigger mill so you can have both low & high speed/torque......
I believe the 3 speed is designed for only big block engines. They said only a certian tire size too, but i can't remember what it is.
the 3speed is good for up to 40series tires/rims but you need a 25 or bigger mill for it to get good results.........
Unless it is racing with friends or something, the track may not allow a 3-speed t-maxx, unless its in the outlaw class.
can you even get to top speed on your track? if you can I still wouldn't get it !!!!!!!
I've got 40 series big joe tires on and there robing the power should i getthe 3 speed trani or a bigger engine?
