Good Cleaner??
Rustler.152.5
I was wondering what a good cleaner would be that i can dip, steel, aluminum, and plastics parts into, and itll clean it pretty well without warping anything.
With out a little bit of scrubbing, idk. But if you have a compressor spray some denatured alchol on there then blow it off. Do that 2 -3 times. Then Spray some wd-40 on there and blow it off. It will look brand new.
No compressor just scrubb with a little denatured alcohol.
Dont worry about warping... i think that a good cleaner is a mild solution of simple green and water. It's fairly cheap and does a good job. The nitro blast stuff in the cans works good on the engine grime, but it is expensive if you use it a lot.
steel and aluminum dip it in carb cleaner, degreaser or some gas.. That will bling it up. The longer ya let it soak the easy it will be to rub off..
I dont know about u, but i have had some trouble finding denatured alcohol. I had to have it ordered. Would regular rubbing alcohol work just as well??
we asked lowes, and they said they didnt have any. we went to the local """"pharmacy""", and they ordered it.
I think that denatured alcohol is methyl alcohol and that is used to make meth so they are getting rid of that and using different tyles like methyl alcohol and isopropyl alcohol, i use isopropyl alcohol and it works pretty good its like 1.50 for like a quart
