I have a t maxx 3.3. I'm having an issue getting it started I've always had an issue getting it started, I bought it used. Its definately getting fuel. I've checked the glow plug and that's working. I've recently put new fuel tank and fuel lines, new wiring harness for the easy start, got a new easy start controller, new glow plug, fresh fuel, still can't get it to start. If I pull the air cleaner off and pour fuel straight into it it'll fire for a second and cut back off. Which would lead you to believe it's not getting fuel but I can watch the fuel go all the way to carborator and it still won't start. I've read posts that if the piston and sleeve are worn out it will give you problems starting but everyting I've seen says it gives you issues starting when the motor is warm but I can't even get it started. I've read alot of posts of people having the same issue but I've tried everyting that I've seen in those posts. Does anybody else have any other ideas?
