Sold / Found getting out of rc
Status
Not open for further replies.
2mcgrath
RCTalk Qualifier
1..i have a monster gt with savage 28 engine set up with roto start.has motor saver airfilter.has 40 series bowties,foward only conversion.also comes with stuff to put reverse back in.also comes with 5 cell hump pack,also comes with a wallcharger for the pack.also will come with the roto start handheld unit.i replaced the switch in it but works fine.you will need battery and charger for that.bushings in steering bellcrank has been replaced with bearings.the diffs have oil instead of grease.also comes with venom micro fail safe.has red and gold shock springs on all 4 corners.also comes with stock springs.the only thing wrong with truck is part of the threaded part of the axle broke off.there is still enough for one nut though.i was running jamnuts and it snapped off even with the first nut.also comes with futaba digital 2pl radio and micro receiver,on 75 am.the radio has rechargable nimh cells.will come with wall charger for charging the radio batteries.i think its a 7hr charger.has a few extra parts also.also have owners manual and box.looking to get $265 shipped in usa.
2..hyper 7 with gs 25 engine set up for roto start,does not come with handheld unit for the roto start.also will come with hyper 21 8 port race engine that needs a new piston and sleeve.has brand new tires and wheels.also will come with receiver and crystals but will need a radio it is on 75 am.has carbon fiber top frame that has a small crack under where the servo mounts but is still usable.has carbon fiber rear shock tower.also comes with spider center diff with only a couple runs on the diff.has futaba standard high tourque steering servo.also will come with a 5 cell flat pack,you will need a charger for the pack.comes with extra gas tank and some other parts.also have owners manual.looking to get $220 shipped.
3.hpi savage with stock 25 engine.has tmaxx tires and wheels,truck is pretty much stock.set up for roto start but does'nt come with hand held unit.has receiver on 75 am you will need a radio.has 4 gear spyder diff mod in rear.truck could use new drive cups evenutally.only thing wrong with the truck is a $6.00 part which you can see at towerhobbies.com part # is LXDLE2..also will come with a force .26 engine that needs a piston and sleeve.comes with owners manual and box.looking for $175 shipped
ill send some pics tonight of the truck.
pics sent guys
no i couldnt go that low.might would go $155 for the savy
back to ya with the info
mgt is sold.still have the .28 engine and radio from the mgt up for sale
welcome
monster gt has sold..but as a roller so i have all the electronics and engine left over from it..
1.savage nitro star k 4.6 28 engine with motor saver airfilter and roto start back plate and roto start hand held unit $75 shipped
2..futaba 2pl digital radio with micro receiver and crystals.also with nimh rechargable cells.also chargers to charge the batteries.$35 shipped
Status
