gears do not shift
abs
RCTalk Qualifier
mumbai
i have replaced my spur gear(18/49). now my savagex Does not shift gear. what could be the reasons???
1. i have checked the spur gear and the slipper clutch.
2. MY ENGINE IS SLIGHT RICH.(WITH THESE SETTING IT USED TO CHANGE PREVIOUSLY).
WHAT COULD BE THE POSSIBLE SOLUTION TO THIS.
NOW IT DOES NOT EVEN DO WHEELY..?????
Slipper clutch is probably loose. Tighten the nut all the way, then back off about 1/16th of a turn. If it comes loose again, search for "slipper coming loose - the fix!". This thread details how to solve the problem.
thanks heart break. will chck. i have also changed my fuel. using 10% temperory. could this b the reason
