Gear shifting?
yveschew
Hi, i know the revo have 2 speed transmission and they shifting automatic?but my revo transmision sometimes are not going to second gear, its that normal or do i need to adjust the transmission? thanks
Make sure you fuel mixture is correct by checking the temp after a few hard runs. I run around 250-260 and mine shifts fine.
Lean the High speed needle 1/8 clockwise each time until you hear the 2 speed. How you ever adjusted the 2 speed since you brought the truck?
and very very careful when adjusting the trans speed..small adjustment at a time or the screw will come off inside and you have to take the trans apart just for a small screw..:)
shifting
make sure that your slipper clutch is tight or it will slip
instead of shift. Another touch of wisdom.
Jay
hi, i just adjust 1/2 turn counter clockwise transmission and they work fine. its that a problem about 1/2 turn because the manual said only 1/8 turn? thanks
