The rust on your crank is probably a result of your after-run oil or lack thereof. Nitromethane has a tendency to absorb water which is why you need to make sure your fuel bottle is sealed before storage otherwise the nitromethane % can decrease and the water content can increase. Even notice the water that appears out of nowhere in your fuel tank on your rc when you leave fuel in the tank overnight? The same thing is happening to your engine when you do not use after run oil.
As far as the salt content being higher than the others, let me check with Sky on that one. I'm sure he has a gas chromatigraph laying around somewhere, they only run about $5000. Honestly I don't think the person you are talking to is trying to mislead you as much as they are misinformed.
I honestly can say that any rust internally on my engines is nothing to do with the salt content but more from operator head-space and timing error.
