TRXaddict
- Racing
So i was just driving my 4.6 around the track and just having some fun ( running perfectly fine)
I have and even blue trail of smoke, responsive, running about 254 or so. Doing alot of hill climbs on the track. Then some top speed runs just adjusting my transmission to the shift point i personally like. I pull it over and let it idle for about 40 seconds because i was looking for something in my tackle box and it cut out. I pick the truck up and lay it on my truck to refill ( did not die because of low fuel level) So i figure i need just alittle adjusting to do. But as I'm getting my screw driver i hear this gargling inside the filter.
I've heard this gargle before and just figure it was because the piston was still in TDC and pressure slowly releasing out while it cools.. But this time i take the filter off while its gargling and i noticed its actually sort of bubbling fuel out of the inlet of the carb.
Not sure if there is residual pressure in the gas tank causing fuel to be still flowing into the carb while the the engine is not running or what.
I've been driving nitro rc's for awhile now and surprisingly I've never had this happen to any of my past engines. How ever I've never owned an HPI before this one. The other models were traxxas.
So anyways just want everyones thoughts on this. I've searched on the forum and could find the subject. Maybe i just didnt search well enough.
Thanks for reading
Thanks for reading
