ok i rebuild my hpi .15 fe and has great compresion but wont stay running . when i prime the fuel about 3-4 times fuel starts coming from behind the flywheel underneth ? why is it leaking ?
Well if you got dirt in your mill and you ran it after that you're gunna have a lot of damaged internal parts. Anyway, yes dirt in the engine could be part of your problem. I don't know how to get the bearing out cause i have never had to do it.
just put a screw driver (flat head) through the back of the engine and catch the race of the bearing and tap the screwdriver with a hammer. Dont be worried if you damage the bearing because your replacing it anyway.
