Sold / Found FS: Dynamite Mega Peak Charger
Status
Not open for further replies.
Domination
This charger is basically new it has not been used more than 5 times so its practically new. It will come with a attatchment to charge humppacks and also will come with 2 extra Fuses. I got the info from RCmodels. $30 shipped FIRM
rc-models_1786_261954550
The Mega Peak is morethan just a peak charger - it's a versatile peak charger capable of charging both electric car packs. This is possible because the Mega Peak offers two different charge rates, 4 amp and 1 amp. The 4 amp charge rate is used for charging 6-7 cell NiCd battery packs as found in most electric cars, trucks, and buggies. A universal receiver plug is included. With the 1 amp charge rate you can safely fast charge any 4-5 cell gas car receiver pack with the included receiver charge cord adapter.
Peak power for peak performance
As A peak detection charger, the Mega Peak allows your batteries to reach their full capacity when charging so you can get the most power and run time from your batteries. It achieves this by using peak detection circuitry that monitors the voltage of the battery pack while it's being charged and automatically shuts the charger off when the voltage of the packs peaks and then starts to drop. This is in contrast to a timed charger, where you often end up with a battery pack that's not fully charged.
In addition, with the Mega Peak all you have to do is select the charge rate and push the start button - there's absolutely nothing to monitor.
Dual inputs
The Mega Peak also featuresAC/DC power inputs. Wit AC power cord, you get the convenience of charging indoors from a household (110-120V) wall socket. For use outside, the DC cord is supplied with alligator clips for connection to a 12 volt power source, such as the 12 volt battery in your car.
Added protection
For added protection, Mega Peak is fuse protected from reverse polarity. Additionally, you'll find that there's a small internal fan mounted to the case for extra cooling. This provides the Mega Peak with a case and faceplate that's not only easy on the touch, but also extends the life of the components. As with all of Dynamite's other Mega Series chargers, the Mega Peak is backed with a 5-Year Warranty.
Summary of Features
Peak detection circuitry
4 amp and 1 amp charge rates
Receiver charge cord adapter
1 amp charge rate is ideal for charging 4-5 cell gas car receiver packs.
AC/DC power inputs
Fuse protected
5-Year Warranty
Status
