Yes you can, if you do that you can go ahead and remove the opti-drive and the servo that controls the forward/reverse selection. That will be a small weight savings, but removing the gears in the tranny by installing the FOC will reduce a lot of the rotational mass and give you more power to the wheels. Like qaart said, with all those gears still in there, they can cause a problem down the line.
