LOL, that's too funny! i'm not too sure what you're talking about with the double sided savage x gear or whatever. I know all the savage trucks use the same spur and slipper pad and what not. hmmmm....i'm tryin to think of something to do...If i could make the pad thicker somehow, it would last longer...i'm curious if i could stick two of the pads together and super glue them to the spur gear if that would work.
and frickenjoey, if you've never ran this thing on 6s, it will blow your mind!!! O and when you do, make sure you put some loctite on the slipper nut because, i've went through some pads really quick with the nut coming loose and the spur gear destroying the pad....just a heads up
