I just got the MGT. From first looks the truck looks a little bigger than the savage. The body is much wider. I like the way the chassis is designed, looks very sturdy. The engine broke in very nicely compared to the savage engine. I like the dual starting ability of this engine. Off road, this is where the MGT shines. IMO it easily out performs my Savage and T-maxx. It seems to handle a little better on pavement. However the savage seems to be a lot faster especially since my savage is powered by the OFNA 8 port. The MGT is lighter than the savage. For some reason the the suspension seems to work very well. It looks a lot like a T-maxx type suspension. The tranny also look similar to the T-maxx except the MGt is transverse design. The 2 speed works very well on the MGT. The push button reverse on the transmitter could easily be accidently activated due to its location. One thing to note about this engine in the MGT is that it has a tendency to go lean when the tank is 1/4 full. I'm not really sure why it does that. The steering servo is strong but VERY slow. I may have to change it because on pavement it takes a long time to turn especially at high speeds. I did not like the tires that came with either the Savage or the MGT so I changed them both. I have the HB 6.5 inch tall, 4 inch wide tires on both the Savage and MGT. The exhaust on the MGT is perfect seems to allow for more low end torque. I will probally change the servo to a faster servo. I may even drop in the ofna 8 port. We will see. For now I'm still trying to see which one I like better. Bottom line for now I would say that the MGT will give the Savage a good run. Off road definetly the MGT one thing is because the MGT has a much higher ground clearence than the Savage. That slow servo has to go. I wish I could figure out why the engine goes lean when the tank is 1/4 low.
