finnaly...
What do you mean the tires are toed out that far? if your looking straight at the front of the buggy are the tires like this? //-----[] or when you look down at the buggy they are like this? //----[] You can adjust these with a camber tool. They are supposed to be []----[] both ways.... once all the tires are straight both ways then your good.unless u want to get technical and have precise angles like the pros....
do you set your buggy up at Zero toe and Camber?
If you do then you should really try setting them the way the factory recommends or how some pro runs it on your buggy....Zero is crazy no control....
look at the pics man.. mine are like this \\-----// i know there is supposed to be a little toe out but i feel that mine is toed to far out.. maby not..
hard to tell from the pics....you should get a guage and set it accordingly.....I'm getting a Hudy setup station myself....
Toe out is desired, and yours looks pretty good. It is hard to tell from the pics as there is a little wide angle to that lense. Also, the rears should toe in, very slightly, to give you more dig to your acceleration.
Gee, Plaid, 20 degress?!?!? j/k. Yeah, you want about 1-2 degrees out in the front and about half that, in, for the rear.
were running 1.5 to 2 out on the front and about 3.5-4 cambers blocks on the rear, if you dont run enough on the rear youl have problems hookin up, and your straight line wilbe not very straight line
Hey, that mill looks familar. Nice to see it getting some new life. Much better than sitting in a box on my workbench.
thanks again rob that thing is a blast.. fires right up every time to.. now i just gotta get the gearing right so it will rap out faster..
