Being new to the Savage, I wasn't sure why everyone was in such a rush to convert to the Ofna sliders on their linkage. But I have finally realized one good reason. With the stock setup, when you apply full throttle, you can also inadvertently apply a fair amout of brakes because the brake linkage binds in the servo horn and it pushes the brake arm so far back that the brakes engage. I almost burned up my clutch tonight because of that. I stopped it just in time. So no harm done. Anyway, since I probably won't be able to get my hands on Ofna parts for a bit, I made my own mods to keep this from happening.
First, I took a bit of extra pushrod I had laying around and I bent it in a loop so it would fit under the top tranny mount screw that's just above the brake lever. I left a bit on the end and bent it out so that it keeps the brake arm from pushing back. Also, when the servo goes to full throttle, it pins the brake linkage against the roll bar which makes it worse. So I put a little "S" bend in the linkage to keep it off the roll bar. Then a little EPA adjust on my XR3i to keep the servo from travelling past full throttle and it seems to work rather well. Now just having to deal with that PITA knob on the end of the brake rod....
