Fail safe
trinbagonet
RCTalk Rookie
LONDON
I have a Hobao Hyper 7 and I am trying to get my elements mini fail safe to work
after connecting it up the green light comes on the fail safe but I cannot move the throttle
any ideas?
They are not all alike, so you'll need to check your manual. If you don't have it, you can find it on line.
Had a look and could not find anything on this particular fail safe
aarrgghh :angry:
Give some info. Probably someone here has the same one.
Did it come with the car? If so, check the owner's manual for setting it.
Thanks
Much appreciated :D:)
all I have is that the failsafe is an elements mini fail safe
You're not giving good information.
Once again, did it come with the car?
If so, the programming information will be in the owner's manual.
If it came with the car and you don't have the manual, then THAT'S the manual you have to get on line.
It appears to be a Euro version of the Duratrax Micro Fail Safe. If it is then reprogramming would be as follows: Hold down the programming button untill the LED flashes. Then hold full brake on your TX and press the button again. Done.
Ok now the failsafe is doing something weird
the throttle is working fine
the red light is constantly on..:angry:
I did what you told me but it did not work..
any other suggestions?
