Fail safe
rickf56
I got two cut out switches in with some parts Ibought they are green and say vxes and have a trim pot with LED no directions any one know how to set up? any help would be nice:\:\
fail safes need to be adjusted, plug one end into the receiver on your throttle channel and the other end into the throttle servo turn the receiver on and the led should light adjust the screw (carefully it can be broken easily) until the throttle is closed and or the brakes are engaged. then turn on your transmitter and make sure the led goes off
You probably have the Venom Fail Safe, like me, but I may be wrong. Most failsafes are tunable by pressing a button on the failsafe while holding brake on your transmitter. It will save that position so when you lose signal, the failsafe will automatically adjust the servo into brakes position. The other type on the one where it uses a knob. Mine has a flat head adjustment screw, and all you have to do is stick a screwdriver down the hole and adjust it. When I turn the screw counter-clockwise or clockwise the position will be set where I stop the adjustment of the screw as the servo moves along when I turn the screw.
