Sold / Found f/t HS-81 mini servo and 18th scale parts f/s
Status
Not open for further replies.
racin_38
port royal
f/s f/t 18th scale parts
i have 2 sets of mini-t wheels and tires ,
first set is a new set of foams F/R
$20.00 shipped
complete set of paddles and blades for the mini-t they are used but are in good shape
$20 shipped
lastly i have a RC18T speed control for those that are looking to seperate there mini-t rx/esc combo's
$25.00 plus shipping
i have pics so email for them if interested
[email protected]
thanx
ok i am going to mod the 81 and get it to work 1 way or another lol
so the esc and tire/wheel combo's are forsale
it wasn't all that hard honestly and it can be done in less then an hour or so
all i did was took the stock servo saver and drilled out the piece that mounts to the servo horn so it is just alittle small to fit over but it can be forced onto the horn .
then just trimmed the ears off the servo and then once i got it in i noticed i wasn't getting complete throw either direction so seen the screw from the linkage was hitting the top of the servo case
so i dremeled it with a small drum sanding wheel ,but be careful there is enough there to trim but if you go too far then you get into the gears !!
then once you have the case dremeled out enough to clear the linkage just install and hold in into the chassis and see if you have your center set and if not just loosen loosen the screw enough to letthe saver slide a tad and jump it a tooth and rechekc,
once you get the center set correctly then just use dbl sided tape and stick it fast
if you dont think the tape will be strong enough then there is room to drill a small hole beside the stock mount screw hole and slide a zip-tie thru and snug it down ,it wont go anywhere
here is a few pics i tried ot take ,but my nerves arent too good for close up shots lol
oh yeah 1 more thing ,here is a link to get a servo saver to fit the HS-81 servo for the 18mt also
http://www.rcmart.com/catalog/product_info.php?cPath=144_621_628&products_id=13267
good job man. I recently got an hs-65 to fit using the stock servo mouting bracket, that took a bit of dremel work to the case as well.
Status
