Savage.30
RCTalk Qualifier
I have lots of parts for RC10GT stadium trucks:
Parts NIP:
-engine mount $12.50
-associated .15 pulstart assembly $15.00
-rear susp. arms $7.00
-front a-arms 7.00
-5 new front wheel bearings in tube $10.00 for all
-outer rear hinge pins $2.00
-slipper clutch disc (2) $4.00 for both
-dogbones (2) $10.00 for both
-rear bulkhead $2.00
-front bulkhead $3.00
-rear stub axles w/pins (2) & dogbone spring and spacer set $12.00 for all
Used parts in good shape:
-Associated .15 nitro engine with pulstart and exhaust manifold, need carb 1gallon thru it ,good compression, will run fine with carb $35.00
-4 beadlocker wheels,2 have Stubby t tires(almost new) 2 have speed hawg street tires, also 2 more speed hawg street tires all have foams good shape$20.00
2 new front wheels with proline "the edge" tires *new* $10.00
-4 shocks w/springs $15.00
-full front susp. setup w/steering linkages installed $12.00
-Full rear susp. setup with drive cups/dogbones -$12.00
-Stealth transmission w/slipper clutch and spur gear, brakes installed $25.00
-Older style stamped steel RC10GT chassis plate $7.00
All prices include shipping, this is probably not all the parts I have just all I could see n one pile
Parts NIP:
-front a-arms 7.00
