Sold / Found F/S Kyosho Loctite NSX FW-04 Special w/ 2 Speed
Status
Not open for further replies.
Ericke1
South Brunswick
Brand New In Box, Kyosho Loctite NSX FW-04 Special w 2 speed. Shipped to your door for $275 (great price, available online for 419.99 from Hobbytron). Paypal, Certified Check, or Money Order payment and clearance required before shipment.
This is a 1/10 Glow Powered, Radio Controlled, 4 Wheel Drive Kyosho Loctite NSX FW04 Special On-Road Car Kit. What makes this car Special is the Optional Fuel Tank, Front Universals, 2-Speed Tranny and Black Alloy Upper and Lower Chassis Set Included W/Kit. FEATURES:Chassis: 3mm Black Alloy Main Chassis and 2mm Upper Deck Drive: Four Wheel Drive Drive Type: Shaft Driven Engine: Kyosho GS15R W/Pull Start and Glow Plug Exhaust: Tuned Pipe W/Header Fuel Tank: 100cc Flip Top Cap Clutch: 2-Shoe Clutch Transmission: Two-Speed Ball Bearing: Set Included Shocks: 4 Oil-Filled Plastic Body W/Coil-Over Spring Main Gear: 37T/41T Plastic Gearbox: Sealed Both Front and Rear Differential: Planetary Geared W/Ring and Pinion Brakes: Single Disk Tires: 2.2" Slick Medium Compound Rubber Wheels: White 1-piece, 18-Spoke Touring Car Body: 2-Door Honda Acura NXS W/Loctite Mugen Decals Bumpers: Front Suspension: Front and Rear Double Wishbone Camber Tie Rods: Adjustable Steering Tie Rods: Adjustable Steering: Bell-Crank Servo Saver:
KIT INCLUDES:
Loctite NSX FW04 rolling chassis with Plastic shocks, GS15R engine, NSX clear lexan body, tires, foam inserts, White 18-spoke wheels 15T/19T clutch bell, 37T/41T spur gear, instructions, full decals
REQUIRES:
Radio: 2-Channel with 2 Servos Radio Batteries: (8) AA size Glow Starter: 1.2 volt Paint: Polycarbonate for body Misc. Items: Fuel bottle, building and track equipment Fuel: 2-cycle glow fuel with 10%-15% nitromethane, 18% lubricant
SPECS: Vehicle- Length: 15.7" (400mm) Width: 8.7" (220mm) Height: 3.9" (100mm) Weight: 4.40lbs (2000g) Wheelbase: 11" (280mm) (wheels on-center front-to-rear) Front Track: 7.2" (184mm) Rear Track: 7.0" (178mm) Ground Clearance: .4" (10mm) Gear Ratio: (1st) 9.04:1 (2nd) 7.08:1 Tires- Front: 1.4" x 3.0" (36x76mm) Rear: 1.7" x 3.0" (42x76mm) Body- Length:19-1/8" (485mm) Width: 9-1/8" (231mm) Height: 5-1/8" (130mm)
PM ME IF INTERESTED.
Status
