ezstart battries
The higher the mAh, the longer the battery will last in between charges. The lower the mAh, the more you'll have to charge it. It really doesn't matter for an EZ Start. I would just buy the cheapest one, high or low mAh.
I use a 2000 in mine, but if it is going to be a long day I snag one of the 3800 packs from my wife's TC3 and use it.
I use some non GB/IB 3000mah (22.00 bux at the LHD)pack for my Revo and my friend uses a stock 1500mah. My pack goes a lot longer without having to charge it. I think it takes my charger about 15mins to charge it also.
The higher the capacity the better.The EZ-Start power the small motor that will spin your TRX.The EZ-Start has a built in protection circuit to stop the small electric motor from spinning if the load is too great. Like in the case of a flooded engine.
I use a cheapie 3300mah brandless battery pack.
