beason
Bash, Fix, Repeat..
the revo is my baby. i have upgraded it to the point that almost nothing on the truck is original. everything that could be died black has been. so here is the list...
black anodized chassis
2 hard coated shocks (two more that just need to be changed out for a total of 6 shocks)
TM 523 engine with ofna sidepipe setup and pullstart
custom side pipe mount
rpm front A-arms
tekno extended rear a arms (makes the wheelbase the same as the 3.3 revo)
tekno wing mount
small wing modded with wheels for pseudo wheelie bar
red traxxas hollow pushrods and turnbuckles
2 hitec 645 servos (one steering one T/B)
tekno radio and battery box mod
mbx-5t fuel tank (very thick plastic and bigger then stock)
aluminum and Carbon fiber trans skid plate
fuel filter with prime bulb
aluminum throttle linkage pivot
FOC
motor saver air filter
17mm hex conversion
chrome rims
losi zombie tires (taped with 3 layers of ductape)
molded race foams
also comes with
3 illusions bodys (two not cut out for sidepipe)
extra chassis (may be tweaked in the back)
extra wing
extra RX battery
pile of springs of different strengths
full set of all rockers
traxxas tool
all stock arms, plus rpm rear arms
all parts to put reverse back in
stock gas tank
stock radio boxes
extra glow plugs
plug ignitors
stock air filter
stock exhaust
other misc stock parts
i think i have trans gears for closed and open ratio, not sure what is installed
piles of shock ends, rubber seal bits, pivot balls, and other odds and ends.
this rig will come RTR minus a radio. i will even include a failsafe. I'm not sure how much fuel has been through the engine, but i dont think its more then a gallon and a half and still runs like a champ. the turbo plugs seem to last longer then regular ones to. I will toss in anything else i find revo related.
all the hoppups were done to make it lighter, stronger or faster, no worthless bling on this one!
I'm looking for $400 plus actual shipping to you. I have perfect feedback on here and ebay
as usual, truck is sold as is, the only problems i know of are the spur gear has a rough spot (still works) and one of the tires needs to be reglued.
rpm front A-arms
tekno wing mount
FOC
17mm hex conversion
chrome rims
molded race foams
also comes with
extra wing
extra RX battery
traxxas tool
stock gas tank
stock radio boxes
extra glow plugs
plug ignitors
stock air filter
stock exhaust
