thanks rob. does RPM make metal arms or are they still plastic? What is wrong with the aluminum ones and integy products? just curious.
Thank you both for the body info
RPM makes only plastic arms & products.
The problem with most aluminum arms is they bend & stay bent, then they have to be replaced, where plastic arms will flex and mostly go right back into shape.
The MAJOR problem with 99% of integy products is they are cast aluminum which is then cleaned up in a CNC mill, giving it the look of a
quality Machined Solid Billet product but without the time intensive machining it takes to make said part out of a solid chunk(Billet) of quality aluminum.
There is little to no Quality control or strength of the cast product.
If your lucky you get one that holds up, if not it bends like a hot stick of butter left next to the hot stove.
Integy's warranty says it all, they only warranty their products till you install it onto your truck, by installing it you void the supposed warranty.
So lets say you get their combo bulks, and the first time you have a good hard cartwheel you bend the tower tabs, your only recourse is to buy
another set, as they do not stand behind anything they sell.
I have little enough cash to spend on my hobby, and the MFG better stand behind their product or they will never see a dime of my money.
I do not expect things to hold up to massive abuse but I have seen some of integy's great looking parts not even hold up to the abuse the stock plastic's shrugged off with no problem.
