Do you have any? Esc you can recommend?If it’s a pop capacitor you would smell it. If so probably have to buy new setup
Buy^^I don’t have any I can part with. I suggest go stock if I were you. Only way I change esc up if you going bigger motor so on. To be safe but one that came with that truck.
Mamba Monster 2 or Max8 is always a safe betSo i need a new esc?
Thats the problem they dont make them anymore..I don’t have any I can part with. I suggest go stock if I were you. Only way I change esc up if you going bigger motor so on. To be safe but one that came with that truck.
Buy^^
The MM2 is the new version of the MM1.Thats the problem they dont make them anymore..
There ya go!Send pictures if you can
Would u have a link of the esc? Or a store where they sell by any chance?The MM2 is the new version of the MM1.
Edit
or if you feel like it use the Traxxas power up program and get the Vxl6s.
There ya go!
I need a motor to go with or can i reuse the old motor the old motor is solder onto the board of the old esc so iam not sureThis what I run but costly and have to run 2 batteries. Let me see what I can find for you.
Here you go
It will work with ur setupI need a motor to go with or can i reuse the old motor the old motor is solder onto the board of the old esc so iam not sure
So i can reuse the old motor?It will work with ur setup
You don’t need new motor
Do i resolder onto the new esc or?
Motor wires unplug from the esc. They can be a little tight so twisting while you pull can help.Do i resolder onto the new esc or?
Your right i got them loos thanksMotor wires unplug from the esc. They can be a little tight so twisting while you pull can help.
