so took the revo out yesterday and drove around for about half a tank half throttleish to warm it up then started to tune. got a great tune front tires barely sitting on the ground at full throttle, got about a tank or two in and noticed my smoke trail just totally dissappereaing then coming back again. happened at both 1/4 all the way to full throttle would just show up randomly through the full throttle range. played with the needles and still had the same issue. the engine only has about a gallon through it. has a fresh plug and using traxxas 20% still have aother unopened gallon of it so I'm gunna prob be finishing out the seaso with traxx 20%.
i pulled the engine and didnt see any leaks as i havent taken anything but the easy start off since i bought it, so i checked there the o ring seemed good and i re tightened with cross pattern. dont have iphone for telemerty or a ir gun yet. any ideas to what may be going on? P.S it idles primes and starts like its on its maiden voyage after break in. "also cranked the flywheel by hand had some good resistance to it.
forgot to add after that day i noticed all this going on i had a small slit in my air intake tube by the spur from a previous crash that i didnt realize i had till after this run i mentioned. i ran it liek this maybe 2-3 tanks could that be the cause aka air leak there or is there crap in the carb now that has to be cleaned out.
